I have a 2002 V70 manual D5 120kW which I really love
Although I just checked the transmission oil and it looks clear and is up to level (was changed ~15k miles ago). Also, the gears shift pretty easy and the gearbox isn't making any "other" noises, hence I'm not really sure.
So, has anyone had a similar experience or any idea what to look at, test or expect (like, should I be looking for a new gearbox
Best regards,
Vents
P.S.
The only other problems I have with the car right now is some weird random (there are silent days and "omg my wheels are gonna fall off days") knocking/clunking noise from front right corner when going over small bumps or even road surface cracks at slow speed, and a quite loud (excessive) popping noise from underneath the valve cover when oil cap is removed (I'm presuming it's coming from vacuum pump).
P.S.S.
A little bit of related service history on the car:
Less than 5k miles ago:
* All four shock absorbers, spring seats and strut mounts,
* Outer tie rods,
* Lower control arm bushing,
* Anti roll bar end links,
* Engine oil and filter (still up to level, changed every 10k km, ~6.5k miles),
About 10k miles ago:
* Power steering pump (used),
* AC compressor bearing,
About 15k miles ago:
* Transmission oil (full service - all fluids, filters, belts, etc.),
* Front engine mount (other mounts look OK)
* Top engine torque mount
About 70k miles ago:
* Flywheel and clutch.
