Supporting hardware for 18t?
Reys
- Year and Model: 850T estate '96
Looking to turn my 15g into an 18T in the next couple weeks. My question for the experienced members (boxpin)... is a stage 1 IPD tune sufficient enough to run an 18T? My exhaust is opened up but still the straight flanged DP. Car is a 96 with strong stage0. Would stock injectors be alright, I would run the vehicle with 16-17lbs max with an mbc alongside the tcv(bcs) to prevent spikes. Anything else I'm missing here
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
With the 18T I think you can run stock internals (that's where the weakness lies) but the main issue is a good tune. As I understand it, boost spikes at low RPM's are what bend rods.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Install a AFR gauge, blue injectors, tune, silicone piping, and a decent boost gauge.
You may also want to install a NA intake manifold and throttle body with the 960 throttle body plate.
- 25 Replies
- 7121 Views
Last post by CIK7
- 1405 Views
Last post by brunocerous
- 15 Replies
- 3637 Views
Last post by StickyPocket
- 3131 Views
Last post by oragex
- 17 Replies
- 3815 Views
