S40 Transmission Fluid Question
I have a 2004 S40 Turbo automatic with 116,000 miles on it. I'm always meticulous about every service. After 100,000 miles I'm changing the oil every 5,000 miles. I have always used premium gas. Just recently I have been having issues when slowing down to a stop -- the car does a hard shift. In 12 years of service, the trans. fluid has never been changed. The manual says change only if I tow something, which I don't. I've been told I need a new valve body. Another place said I should try a transmission fluid flush first. The fluid was checked and it's a very dark brown color. I have the following questions 1) should the transmission fluid ever be changed in a Volvo? 2) How can I be sure it really is a valve body problem? 3) Is it possible the transmission problem is a result of NOT changing the fluid ever? Any other advice appreciated. Thanks.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
1. Though the owner's manual doesn't state it, yes, it is a good idea to have regular transmission fluid changes.
2. I don't know.
3. I suppose it's possible.
I would do a fluid exchange. I would not do a "power flush'.
At this point, what do you have to lose.
FWIW, I do a sump drain / refill every 15,000 miles.
2. I don't know.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
cbburtraw
- Year and Model: 1998 S70T5M, 01 V40
Just change the fluid using JWS 3309 spec fluid. Don't use a flushing machine. Just drain the fluid, undo the cooling line, and keep adding and draining fluid until it's clean.
BTW, an OEM isn't going to recommend a service that can be stretched to 100K or more. At that point, they don't care much and it could potentially cause dealer headaches. I'd go with a 50K interval personally. Some will say more often, some will say less. YMMW.
I doubt it's a valve body problem... that's a strange diagnosis to make IMO. These are basically Toyota transmissions (made by Aisin) and they're pretty good units with fresh fluid.
I did a fluid change on mine last month and it made a world of difference. I thought mine was more or less fine, but it shifts perfectly now. Especially the torque converter clutch lockup function.
It's worth $60 bucks and an hour or two to at least try. Be sure to get the LEVEL right by following the right procedure. Changing a valve body probably isn't easy to do and would probably require transmission removal...
Fluid I used: https://www.amazon.com/Mobil-55221-Auto ... B00BLKXW9O
Tutorial: http://v70r.com/forums/topic/61542-tran ... -fill-diy/
(tutorial is actually for an s/v 40 despite the website)
I got a tranz filter from Auto Zone. Kinda strange that they would have that, since you're not supposed to change the fluid.
I recently changed out the radiator and that is what gave me the idea to change the filter. So I will be doing the fluid exchange soon. I saw quite a few posts that recommend that vs. the flush.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The filter is ONLY accessible by total disassembly of the transmission. Get your money back if you can.
mf70
- Year and Model: V50 2006
- Been thanked: 2 times
As to the OP question #3, avoiding damage is the POINT of changing the oil. You have a hidden dip stick for the trans fluid, Have a look at the fluid. If it's brown or black, change it out. There are a number of threads on the procedure.
- 882 Views
Last post by difflock54
- 3352 Views
Last post by pmondrian
- 1704 Views
Last post by erikv11
- 896 Views
Last post by BrianV70
- 1123 Views
Last post by RickHaleParker
