IPD sale Volvo Parts
Did you know? 🤔
What did you do to your P2 Volvo today....now sticky!!
2001 - 2007 XC-70
BlackBart
Has thanked: 24 times
Been thanked: 16 times
Sweden
BlackBart
Re: What did you do to your P2 Volvo today....now sticky!!
Post by BlackBart » Thu May 02, 2019 4:13 pm
I HATE it when deers do that!
1994 850T wagon
2004 XC70 wagon
Want: '67 122 wagon
E Showell
Year and Model: V70 '98 FWD NA 5spd
Has thanked: 3 times
Been thanked: 26 times
United States of America
E Showell
Post by E Showell » Fri May 03, 2019 3:26 am
So, the c. 90 mile round trip test drive back and forth to work reveals Ruby Red to be driving smooth as glass. I did not think it was bad before. This is spectacular. The only thing I dislike about the XC70 is the exterior styling. They are just not attractive cars.
'99 V70 NA FWD Auto, dark blue (soon to be for sale)
'99 S70 NA FWD Auto, black (sold and resurrected)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
Has thanked: 180 times
Been thanked: 542 times
Trinidad & Tobago
Post by abscate » Fri May 03, 2019 3:35 am
You should have asked for Ruby Red as a P2.
That was/I said a great deal, even better than Evita! Please avoid Nissan Rogues...
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
BlackBart
Sweden
BlackBart
Post by BlackBart » Fri May 03, 2019 10:46 am
At ALL COSTS!!
1994 850T wagon
2004 XC70 wagon
Want: '67 122 wagon
E Showell
E Showell
Post by E Showell » Mon May 06, 2019 1:47 pm
Yesterday, actually. First oil change on wife's newish to us 2007 S80 3.2L. Owner's manual lists sump capacity as 7.8 quarts. Should I be concerned that it took close to 8.5 qts. to reach top of dipstick fill region? I let the bulk of the fill sit overnight before topping up this a.m.
Getting the oil filter out is a bit of a trick. I never took the filter cap out of the vehicle, I just put it on its side and slid the filter and O-ring off that way. I had to lift the power steering reservoir out of the way and needed a 1/2 drive wobble joint and 10" extension to get the filter cap off with a 36 mm socket. The design is a bit of a puzzler, but I didn't take the press on engine cover off either. That might have made it easier.
BlackBart
Sweden
BlackBart
Post by BlackBart » Mon May 06, 2019 2:58 pm
That doesn't sound right. If you only put in seven and a half and it reads overfull, then it hasn't gotten into the filter yet and will come down. But if you put eight and a half qts in....then there are eight and a half qts in it. It's too full.
If the dipstick wasn't pushed all the way in, it could read too low.
Oversized filter? Holds more oil?
1994 850T wagon
2004 XC70 wagon
Want: '67 122 wagon
E Showell
E Showell
Post by E Showell » Mon May 06, 2019 4:07 pm
It isn't reading overfilled. I am basing the amount in the system on the amount of oil added based on a rough reading of the markings on the side of the 5 quart oil jugs from which I filled. At 7.5 quarts it was barely registering above the "twist" at the very tip of the dipstick. Took almost another full quart to get it to the "full" mark on the dipstick. Dipstick is fully seated. I checked and double checked. There are postings on other fora (forgive me father for I have sinned) suggesting that the 7.8 quarts specification for the 3.2l I6 is not accurate, and the actual amount required is closer to 9 quarts. Just wondering if that matches anyone's experience here.
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 14 times
MDK
Post by MDK » Mon May 06, 2019 6:25 pm
Well boys and girls... I just did what that call a " pump down/ pump out. 2002 V70 2.4 NT. I bought 12 quart's of the aisin T1-V. Checked the dip stick..reads full at cold mark ✓
Trinidad & Tobago
Post by abscate » Tue May 07, 2019 5:43 am
Evan , other than being on the dipstick it won’t make any difference to engine operation if you have 7,8,9 quarts/liters in the sump. Just find the amount that gets it mid range on level ground, enter it into the log, and roll. Check after a hot run, 15 minute drip down, too.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
oragex
Year and Model: S60 2003
Has thanked: 77 times
Been thanked: 151 times
Canada
oragex
Post by oragex » Tue May 07, 2019 7:55 pm
Got the brake booster seal from URO, waiting now for a moment to install it - in fact I will first practice a little at the junkyard. Have to say the quality looks good, there is some silicone grease and the pipe used to press the thing has an angled end (important) and the URO video also shows an important part about bending the lip of the seal at @2:30
https://www.ebay.com/itm/Mercedes-W212- ... 2749.l2649
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
