Did you know? 🤔
2001 - 2007 XC-70
- Pete -
Has thanked: 55 times
Been thanked: 81 times
United States of America
- Pete -
Post by - Pete - » Wed Sep 11, 2019 10:13 pm
Took a full body shower using Zerex G-05 today. Even had a mouthful of it at one point but couldn't find my toothbrush. Amazing how much coolant comes out when you crack open the bottom turbo cooling line. Also amazing how much drinking it takes to remove that flavor from your mouth.
Anyhow, removed a bevel gear & driveshaft (again) for fun, just to make sure I "still had it". Fortunately that exercise wasn't for naught. Turned out the DEM pump had ceased operating so put a new one in for resumed AWD function.
matthew1 wrote:
Tue Sep 10, 2019 4:14 pm
Whoa. My iPD gauge had proper markings. The problem with those is that you couldn't see them :lol: https://www.matthewsvolvosite.com/boost ... stall.html
I didn't notice any notchy action.
Like you, I struggled with placement. Headliner, A-pillar, instrument cluster... I tried them all.
I believe yours is a previous generation.
Yep, my IPD one is notchy (not horribly), and there aren't any kinks in my nylon line. Looks like they used to use vinyl tubing, wonder if that accounts for the difference in action? The $14 ebay one is smooth as silk & every bit as accurate as the IPD one & has a smoked lens that appears black with the ignition off. Not ripping on IPD, I love lots of their stuff & have spent oodles with them (haven't we all?), simply saying their gauge isn't worth $60 or $70 or whatever it costs.
I still need to wire them so they are dimmable.
Anyone want to wager a bet as to how much longer this collar sleeve/BG input is going to last? 276,500 on it as is. $5 beer money to the winner.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 13 times
Been thanked: 67 times
E Showell
Post by E Showell » Thu Sep 12, 2019 4:23 pm
Went with the Premiers.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 569 times
Been thanked: 220 times
matthew1
Post by matthew1 » Fri Sep 13, 2019 8:36 am
It's gotta be the mechanics of the gauge -- your IPD -- that are low quality to make the notchiness. The tube's the tube. Air pressure is air pressure. Could be metal, rock, or plastic, it's all the same.
When you get it to dim by wiring it to the gauge cluster, you'll have that Tingly DIY Feeling™ we all get every so often. $5 beer money says it.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Antoine240bk
Year and Model: XC70 2.5T-2006
Has thanked: 10 times
Been thanked: 14 times
France
Antoine240bk
Post by Antoine240bk » Sun Sep 15, 2019 4:19 pm
Did a full maintenance to the XC70 8)
Rear rotors & rear brake pads and handbrake pads with new springs.
Front brake pads and a good clean on four brakes.
Oil drain & oil filter, air filter and a carbon cabin filter.
Spark plugs, petrol filter
Bva drain & fill 3.5l (Automatic gearbox) :wink:
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
TheMrFailz
Year and Model: 2002 V70 2.4T
Has thanked: 7 times
TheMrFailz
Post by TheMrFailz » Thu Sep 19, 2019 12:58 pm
Blew my transmission up a couple of days ago pulling into a parking lot. Good old aisin.
Professional jerry-rigger.
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Post by abscate » Thu Sep 19, 2019 1:56 pm
Yeah, Volvo transmissions suck. My Toyota ones last forever.
:D :D :D
Link To Volvo Glossary
TheMrFailz
TheMrFailz
Post by TheMrFailz » Thu Sep 19, 2019 2:07 pm
:D :D :D
Think you've got that one backwards there friend. :D
ionianp2
Year and Model: 2004 Volvo s60
Has thanked: 1 time
ionianp2
Post by ionianp2 » Fri Sep 20, 2019 1:42 pm
I replaced the steering rack boot on my S60, as it was brittle and with two holes. Luckily I was able to slide the new boot through the tie rod joint.
Also sprayed some AT 205 on surrounding bushings to rejuvenate them.
Has thanked: 95 times
Been thanked: 284 times
Post by erikv11 » Fri Sep 20, 2019 9:47 pm
... When you get it to dim by wiring it to the gauge cluster, you'll have that Tingly DIY Feeling™ we all get every so often. $5 beer money says it.
You can also wire it to the accessories connector, maybe it's the pink wire that dims with the dimmer switch? Don't remember ...
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
Post by erikv11 » Fri Sep 20, 2019 9:50 pm
Last night I moved the S60 R from the front of the house to the back, went to move it again and the key wouldn't turn! As is common, the pot metal pin had broken off.
This morning I Dremeled open the steel plate underneath the lock cylinder, dropped out the broken pin, 40 minutes later the car was back on the road.
Hopefully this fix is enough, I didn't see any other pieces jammed up or floating around in there.
Also, last Saturday on the same car I replaced the fuel pressure sensor. Car would sporadically hesitate just a bit, and the code for FPS was detected by VIDA. There was no CEL. Bought the Bosch unit, installed, problem didn't surface again this week and no code set so far.
'96 855 NA, 145k
'06 S60 R, 167k
