OK, Got It. GLOVES! Thanks.
- MoVolvos
- Year and Model: 03S80T6~08C30T5
- Has thanked: 46 times
- Been thanked: 109 times
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- tyguyc
- Year and Model: 2004 xc70
If you wanted to avoid the gloves, doing it near a sink may be a smart move. that way you can just wash your hands after.
- E Showell
- Year and Model: V70R '06 AWD Auto
- Has thanked: 35 times
- Been thanked: 86 times
If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'95 855 auto (sold)
- tyguyc
But what if you like cleaning the brake dust off your rims? What produces the most brake dust? and wont chew through rotors?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 124 times
My Spanish made Bosch pads certainly seem to do the trick so far
ATE Ceramic pads are on the list for next time anything needs replacement. Or by spring. Depends a bit on how long I think I'll keep the car. Though there really isn't anything wrong with it and anything to match it's power/weight ratio is going to be either expensive or as old.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 79 times
- Been thanked: 14 times
Started LCA, Ball joint, Inner & Outer tie rods today on my '06 V70. Went with all Lemforder parts except inner tie rods (TRW). Broke down one side, taking the struts out will make job a little more roomier. Rear LCA (hockey puck) bushing shot, as well as tie rod end. I think I read somebody used 2" PVC pipe for installing ball joint, it does fit perfectly over ball joints boot protector sleeve. With one threaded end and 2" threaded galvanized cap for pounding on, it just might work.
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1336 times
Press available up in the North Country if you get stuck (or your balls, I mean, Ball joints)
Route 32, just South of Albany
Link To Volvo Glossary
- GlennG2759
Thanks abscate, I'm about 50 mins. south of you and I might take you up on that. I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
Glenn
- MoVolvos
Great job Dad, teaching your daughter to be handy!GlennG2759 wrote: ↑Wed Nov 06, 2019 3:45 pm I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- GlennG2759
Iinstalled new ball joints in steering knuckles on my '06 V70. Used 2" by 4" galvanized pipe with cap, worked perfect. About half dozen shots with a 5 lb. hammer and they were home.
- 83 Replies
- 13396 Views
Last post by erikv11
- 2205 Views
Last post by mrbrian200
- 10 Replies
- 2360 Views
Last post by BlackBart
