IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 37 times
Been thanked: 82 times
Post by MoVolvos »
tyguyc wrote: Tue Nov 05, 2019 10:04 am
MoVolvos wrote: Mon Nov 04, 2019 4:28 pm
tyguyc wrote: Mon Nov 04, 2019 1:13 pm Finally cleaned off my radio knob with hand sanitizer. So. Much. Better.
Did it have the sticky coating and if so were you able to completely remove it?
Indeed. and also Indeed.
I used purell, not that it really matters. and took two paper towels to get everything off my fingers.
OK, Got It. GLOVES! Thanks.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
tyguyc
Year and Model: 2004 xc70
Has thanked: 1 time
Post by tyguyc »
If you wanted to avoid the gloves, doing it near a sink may be a smart move. that way you can just wash your hands after.
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 35 times
Been thanked: 79 times
Post by E Showell »
If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
tyguyc
Has thanked: 1 time
Post by tyguyc »
E Showell wrote: Tue Nov 05, 2019 1:25 pm If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
But what if you like cleaning the brake dust off your rims? What produces the most brake dust? and wont chew through rotors?
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 124 times
Post by Rattnalle »
tyguyc wrote: Tue Nov 05, 2019 1:41 pm
My Spanish made Bosch pads certainly seem to do the trick so far :D
ATE Ceramic pads are on the list for next time anything needs replacement. Or by spring. Depends a bit on how long I think I'll keep the car. Though there really isn't anything wrong with it and anything to match it's power/weight ratio is going to be either expensive or as old.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 74 times
Been thanked: 13 times
Post by GlennG2759 »
Started LCA, Ball joint, Inner & Outer tie rods today on my '06 V70. Went with all Lemforder parts except inner tie rods (TRW). Broke down one side, taking the struts out will make job a little more roomier. Rear LCA (hockey puck) bushing shot, as well as tie rod end. I think I read somebody used 2" PVC pipe for installing ball joint, it does fit perfectly over ball joints boot protector sleeve. With one threaded end and 2" threaded galvanized cap for pounding on, it just might work.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 379 times
Been thanked: 1186 times
Press available up in the North Country if you get stuck (or your balls, I mean, Ball joints)
Route 32, just South of Albany
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
GlennG2759
Thanks abscate, I'm about 50 mins. south of you and I might take you up on that. I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
MoVolvos
Post by MoVolvos »
GlennG2759 wrote: Wed Nov 06, 2019 3:45 pm I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
Great job Dad, teaching your daughter to be handy!
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
GlennG2759
Iinstalled new ball joints in steering knuckles on my '06 V70. Used 2" by 4" galvanized pipe with cap, worked perfect. About half dozen shots with a 5 lb. hammer and they were home.
For about $7 bucks
For about $7 bucks
