IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 272 times
Been thanked: 849 times
Trinidad & Tobago
Post by abscate » Sat Dec 14, 2019 7:53 am
Right, that’s the problem, of course,
I’m only cleaning half the connector, the other side is causing heat, and reoxidosing the fuse blade
Does anyone make an abrasive file the same thickness as a fuse blade to solve this?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
RickHaleParker
Has thanked: 3 times
Been thanked: 433 times
United States of America
RickHaleParker
Post by RickHaleParker » Sat Dec 14, 2019 8:52 am
You might be able to fine a Jeweler or Watchmaker file that will fit. Filing is another band aid fix. It removes the top layer and make it more subject to corrosion.
A better option is to get a set of pin extractors, remove the terminal from the REM side and replace it. The tricky parts are figuring out which pin extractor to use, then sourcing a replacement terminal. However if succeed it is a permanent fix rather then a band aid fix.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
1997 S90, B6304S, AW30-42, Bosch Motronic 4.4 - Sold
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 9 times
Been thanked: 54 times
E Showell
Post by E Showell » Sat Dec 14, 2019 12:25 pm
Why permanent fix? Why won't the new terminal just oxidize?
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
Trinidad & Tobago
Post by abscate » Sun Dec 15, 2019 12:11 am
I would love to know root cause on this one. It’s the only car of 6 in the driveway that has this problem
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Dec 15, 2019 1:07 am
Permanent because the repair will out last the car.
Step one: Pin Extractor set. These are the tools used to compress the retaining clip(s) so the terminal can be pulled out of the plastic block.
A lighted Loupe comes in handy. For peeking into the connector to see the clips.
Trinidad & Tobago
Post by abscate » Sun Dec 15, 2019 6:07 am
When I pulled the REM fuses everyone had the black corrosion on them. My best guess is there is moisture in the rear left wheel well ( wagon) that exacerbates fuse corrosion.
I did have some on my P80 relays once, after 15 years , and cleaned them too, but that hasn’t recurred.
viewtopic.php?f=1&t=80481&hilit=Albany&start=20#p434364
E Showell
E Showell
Post by E Showell » Sun Dec 15, 2019 12:58 pm
We'll, thankfully the weather held out and bro and I did the rear pads and rotors on the V70R having tackled the front brakes last weekend. Brembo and Akebono ceramic pads. Won't be cleaning the wheels for a while.
New windshield cowl seals for Ruby Red and new wiper blades for the '99 V70 and a rear wiper for the R as well (which also got a new expansion tank cap). Coolant looked a little low last week and I didn't like the look of the residue I saw on the tank near the filler neck.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 36 times
Been thanked: 57 times
- Pete -
Post by - Pete - » Sun Dec 15, 2019 10:04 pm
Oophta x2.
1) That set of brakes set you back some pennies.
2) Keep a close eye on that coolant. Is this the same one you blew a head gasket on? Or was it a cracked sleeve? It’d be hard for me to not be doing compression & leakdown tests. What coolant did you run it it?
2001 V70XC 142k
2004 V70 AWD 134k
2004 V70R M66 142k
2004 XC70 278k
2006 XC70 155k Sold
E Showell
E Showell
Post by E Showell » Mon Dec 16, 2019 8:34 am
Different engine. This is the replacement engine. Running Volvo coolant only. I'm thinking the coolant was evaporating out past a bad expansion tank cap seal.
The brakes weren't cheap, but the money I saved in DIY helped take a bit of the sting out. Plus, brakes are brakes. Can't do without 'em.
BlackBart
Has thanked: 58 times
Been thanked: 39 times
Sweden
BlackBart
Post by BlackBart » Mon Dec 16, 2019 5:03 pm
Do you think from above - glass seal....or from below - spray from the wheel?
1994 850T wagon
Is it time for a 1964 122 wagon?
