Where do i look for answers?
The AC only blows on the feet.. what part need change.. uhh its just like driving a sauna ... HELP..!!
im losing too much weight already
940 AC problem.. cold only on feet
jimmy57
- Been thanked: 320 times
No vacuum supply to climate system. Hose runs from passenger side firewall inside to the controls on dash. The hose on engine has likely split and fell off its fitting. The default door position is floor/defrost.
There are other things that can make the system have vacuum leaks but usually you will have some periods of the system blowing out the correct places and it goes to floor/defrost on hills or when you accelerate.
