98 S70 Rear Exhaust Bracket Part Number Question Topic is solved
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Hey everyone,
Just spent over a half hour (correction, 19 hours...) trying to find out what rear exhaust bracket this is... I can't find the correct part number.
This is my rear-most exhaust bracket.
I'm looking through the parts diagram here: http://www.volvopartswebstore.com/showA ... evel=24656
But cannot find it...
It's not 9434431
https://www.eeuroparts.com/Parts/110083 ... r-9434431/
Nor is it 9470686
https://www.fcpeuro.com/products/volvo- ... et-9470686
Oh my gosh... So the original piece has been redesigned (I can tell by the lip of 9434431) and you have to install both these pieces together, huh? Seems a little over engineered if you ask me... Can anyone give me a confirmation here? Thanks!
Retired:
2015 Volvo S60, T5, 85K
Has thanked: 2200 times
Been thanked: 1852 times
It depends on which chassis # you have on your car. The link you give for the layout states for NA cars. Alternate 1 and Alternate 2 depending on chassis # for item #28. 26 looks like is a stiffener plate for either option. Sorry don't have a FWD to compare.
theWIFES_S70
Neil, thanks for replying. Our car is an N/A. I can't see how else this would work unless you install both pieces. I can kinda see one sliding into the other... That sort of makes sense, no?
Retired:
theWIFES_S70
So after further analysis of this part, it is clear to me that I need 9434431.
However, I cannot for the life of me find the part that bolts onto this piece. 9434431 connects to the frame of the car and the hanger piece bolts onto this piece with two 12mm bolt holes.
This is the information from the parts diagram...
28 Bracket Part Number: 9470686
S70 FC 1; CH 571090-, FC 2; CH 572194-, V70 CH 550089- FC 1; S70 CH 439914-571089, FC 2; S70 CH 438063-572193, V70 CH 374345-550088
ALTER 1 ALTER 2
So confusing... :o Does this mean that part 28 is the same regardless of the variation?
Retired:
theWIFES_S70
The plot thickens! Good ol' Skandix to the rescue! They're the only ones with a photo of this original part. http://www.skandix.de/en/spare-parts/ex ... r/1031487/
This is VOLVO PART: 3547625
And it's been discontinued...
http://www.volvopartswebstore.com/produ ... 47625.html
:shock:
Retired:
beigg
Year and Model: 850 97
Post by beigg »
I'd thought #36 is what you'd want...
ugh smh 850 Turbo fridge
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Man, all of that stuff is like brand new in our salvage yard. If you'd like me to get you that stuff send me a pm.
I tried to get bolts for that thing for our S70 5 years ago and Volvo told me that they were discontinued then. I was really surprised. I had to use bolts from a 960 hood.
theWIFES_S70
I'll probably just get an array of bolts from boltdepot.com... It's always a good idea to have an array of high quality metric flange and hex bolts lying around... Just sent you a PM Robert!!
Retired:
theWIFES_S70
So according to FCP,
985186
Mounts with 2x of 985186
Which of course, are discontinued.
I can't see how it would mount with two bolts, but I'm going to assume there's something there I can't see because of how the part was photographed.
I'm almost certain these are 12mm bolts...
The exploded parts diagram only shows one bolt that you need two of and I checked it and a 1/2" SAE socket fits around it. Now to figure out how long it needs to be...
I'm thinking 30mm or 35mm in length, if I had to guess...
https://www.boltdepot.com/Metric_flange ... .75mm.aspx
edit:
Just received my bolt order, I guess I should have paid more attention to the specifics. Yes, the boltdepot link above points to 12mm bolts, but 12mm bolts does not mean 12mm socket size bolts! (These are 16mm across the head...) The OE Volvo bolts are 12mm socket size bolts. Which means these are MOST LIKELY 8mm (JIS) flange bolts (12mm head!!) bolts. Guess it's time to place another order... :roll:
Retired:
theWIFES_S70
OK, FCP order is in. Bought everything I could, even this sillyness... (Which shows up in the exploded parts diagram...)
A PIECE OF SWEDISH FELT!
Part no.: 3537385
And a bunch of 12mm bolts in varying lengths from boltdepot.com. They're great with returns, too... Can't wait to put a green check on this thread and be done with it!
Retired:
