How to disconnect electrical plug from idle air motor?
Larva
Year and Model: 1993 850
Post by Larva »
I'm in the middle of removing my intake manifold from my 93 850NA to replace the PCV system and clean the EGR . I need to remove the electrical connection from the idle air motor and its stuck. Is it a simple push on pull off plug or is there a mechanical release that I am not seeing?
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
There is a mechanical release. Wire type push then pull plug off.
Has thanked: 1610 times
Been thanked: 4065 times
Push and hold the wire, the wiggle the connector.
Larva
Post by Larva »
Thanks, got it.
