93 850 consensus on spark plugs?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Volvo OEM.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Volvo oem or equivalent:
-NGK BKR6ETUC
-EYQUEM RFC 52 LS3
...the ones which are inside of Volvo oem spark plug package.
-NGK BKR6ETUC
-EYQUEM RFC 52 LS3
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Bosch, NGK coppers work fine and are inexpensive. Denso is another option. No on Bosch platinum. Yes on NGK platinum. What does your manual say?
M1 10W-30 HM
M1 10W-30 HM
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I got the NGK coppers, will install them tomorrow.
Ignition is working. I used the inline tester and a ground wire on the plugs to test each one; they all spark, a couple brighter than the others. And they smell of gasoline so I guess some fuel is spritzing into the cylinders—and there's plenty of pressure at the fuel rail / schrader valve.
Strange that in June it started instantly after sitting since February, which is how it has always started in the 8 years I've owned it, even after sitting for long periods. But now not even a pop, no hint of life!
Maybe the plugs will make a difference. Seems like a long shot.
- sleddriver
Be sure to properly gap.
I myself would never let any car sit that long without starting it.
M1 10W-30 HM
M1 10W-30 HM
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I have good luck with Bosch copper. They won't last as long as O/E though.
Good luck.
Good luck.
- Has thanked: 311 times
- Been thanked: 817 times
My first thought is lawn mower syndrome, definitely give the oil-in-each-cylinder routine a try.
- 3289 Views
Last post by ndphotonl
- 20 Replies
- 11715 Views
Last post by Brumbachjohn
- 14 Replies
- 4729 Views
Last post by matthew1
- 17 Replies
- 2609 Views
- 3159 Views
