Tailgate will not open on 2009 XC 70 3.2
I realize this is not a "new topic", but in the archives I don't see anything to answer my question. The tailgate is stuck in the closed position. When I try any of the ways to open it (fob, dash button, or handle), it makes an electronic click-clunk that is audible. I removed enough of the trim to see and get a hand in where the motor(s) and cables are. The bottom cable that goes from the center motor to what looks like another motor toward the right side of the car seems to have broken away from a clip/mount near the center motor. Working with info from the archives I unhooked the yellow clip which holds the top cable from the switch at the top of the tailgate. I've tried pulling and pushing these cables and pushing the fob button in every combination possible to get the tailgate open, and I've been unsuccessful. If there is anyone who knows which cables should be pushed or pulled in what combination or how I can get the thing open at all, I'd be very appreciative. It seems like if I could get it open and take the trim off, I could figure out what needs replaced or repaired.
- pierremcalpine
- Year and Model: V40 2003, V70 2010
- Has thanked: 2 times
- Been thanked: 5 times
wow, what a royal pain. You may need to get someone at your local dealership to give you some advice. Have you tried pulling on the cable while someone else presses the button? Just a guess.
Thanks. Yes I have tried pushing the top cable and pulling the bottom one at the same time. There is a notable click and the bottom cable comes out another 1/8 of an inch, but that's it. I guess I will take it in though it makes me feel defeated (and poorer).
- pierremcalpine
damn! I hate admitting defeat! Have you tried spraying some lubricant in the assy and then seeing if it makes a difference...not sure this will help...good luck! There was a thread out there regarding someone who had to take the tailgate off forcefully...I will see if I can find it. The dealership ended up doing it and it did require damaging some parts...
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
On my 2010 XC70 3.0 my hatch would not operate. When the key fob was pushed the hatch latch would would actuate but there was no lifting motion happening. I could hear a pump motor sound but no vertical movement from the tailgate. There are two hydrolic hoses (P/N 31218396) from the pump in the drivers side wheel arch going up the hatch pillar to the actuator for the hydrolic ram in the roof under the headliner. These two 8mm black plastic hoses had been kinked leading to cracks in both hoses. The trim covering the wheel arch, hatch rear pillar and drivers side head liner will need to be removed and or dropped to have access to all of the components. Replaced hoses and refilled the hydrolic fluid and system works.
- 2970 Views
Last post by 321lor
- 5288 Views
Last post by pierremcalpine
- 2626 Views
- 989 Views
- 1063 Views
Last post by chrism
