Maximum Block and Head Distortion - B5234T Topic is solved
Hoytster
- Year and Model: 1995 850 Turbo Wagon
I apologize if this has been covered but I haven't been able to find anything by searching. I bought a 95' 850 Wagon (88k, 5 speed swapped) for $200 that needed a head gasket (due to overheating). I tore it down and measured the head at .024 out lengthwise. From what I have found on this site, that is way beyond spec as to what can be machined, so I believe the head is junk. I measured the block at being .003 out lengthwise, but haven't been able to find a spec for how much distortion is allowed on the block. Does anybody have this information?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Was fluids mixed?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
OP said he bought it so I imagine he doesn't know the history. Besides that's not what he asked about.rspi wrote:Was fluids mixed?
Hoytster
You are correct, i dont know much about the history other than it overheated and was taken to a garage. There was no coolant in the oil when i bought it, but there was plenty of oil in the coolant. Exhaust gas in the coolant resevoir and it would push coolant out when started.polskamafia mjl wrote:OP said he bought it so I imagine he doesn't know the history. Besides that's not what he asked about.rspi wrote:Was fluids mixed?
polskamafia mjl
My Haynes manual only lists specs for the cylinder head. Is it possible that there's no range for the block and instead it should just be decked? I've never rebuilt a motor so I don't know.
Hoytster
I know most motors have a range. General rule of thumb I've heard is no more than .003 on a v8. And no more than .005 on a inline 6. I've never heard anything about an aluminum block inline 5....
JDS60R
- Been thanked: 3 times
Block is normally a thousandth per cylinder. The block is much harder to warp. So normally on a 5 cylinder I'll see 2-3 thousandths max if any.
The head is normally out 6 thou unless its been overheated. There are machining notches in the head- recessed areas that you should not cut past. If the head hasn't been cut there should be more than .024 in there. Take it to your machinist and have him measure. Sometimes they will heat the head and straighten it to within 8 thou or less and then cut.
I had a couple of 95 850's and loved them. The piston rings could use a little help. Technology has increased since then quite a bit. I like to put on a set of new Total Seal piston rings while the engine is apart. It gives me a chance to inspect and replace the bearings while I'm in there. A few hundred on rings and a hundred or so on bearings and you have really brought that car back to life.
Keep in mind with the head being out .024 it probably saw some heat so I would check the block for out of round cylinders and consider all the aspects of the motor before fixing anything . Plenty of good used engines that you can put in there. Lucky even did a video on putting a newer model engine in there.
Retired
Hoytster
JDS60R wrote:Block is normally a thousandth per cylinder. The block is much harder to warp. So normally on a 5 cylinder I'll see 2-3 thousandths max if any.
Thanks for the information. That is exactly what I need!
- 1831 Views
Last post by SuperHerman
- 1042 Views
Last post by MadeInJapan
- 6553 Views
Last post by MarianoHSN
- 3951 Views
Last post by Colomonza
- 11 Replies
- 5673 Views
Last post by Sommerfeldt
