What is the interchange on 1993 850 coolant recovery tanks?
I found the part number 9141106, listed for '93s, and 9141095, which at least one vendor says will fit but is listed for '94-up applications.
1993 850 Coolant Recovery Tank Interchange?
slantvaliant
- Year and Model: 1993 850
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Should fit. I seen no difference in the '93 850's that I've seen.
- Has thanked: 2199 times
Vida shows 2 different tanks, one for -93 and another for 94-98. Don't know what the difference is as the pictures for both parts on Vida look identical with one larger pipe running to the back of the engine and another pipe to a connection on the thermostat housing. Maybe the method of the part mounting is different?
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Whatever you do, do NOT buy an aftermarket tank. They last about 6 months and will split and crack right on the seam. Better off getting a used O/E at a pick and pull if you are tight on cash.
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
If anything about a part changes most companies will change the part number or dash number. If the part number is for an assembly and any part in the assembly has been changed the assembly part number will be changed. So say volvo or its supplier hypothetically decides to change the type of plastic in the tank. You wouldn't necessarily be able to tell a new tank from the old one because they would be identical as far as you could tell by looking at them. If parts change and new part numbers aren't assigned companies can get faced with combined stock and not being able to tell one part from another if they are very similiar.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
They all look the same to me.
Maybe the ones up to '94 doesn't have a low coolant sensor in it....just a guess.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
I totally agree.shaker_chi wrote:Whatever you do, do NOT buy an aftermarket tank. They last about 6 months and will split and crack right on the seam. Better off getting a used O/E at a pick and pull if you are tight on cash.
shaker_chi
I have an early base 94 with the 1993 taillights, aluminum control arms, etc. and my tank has a low level sensor on it.
