I'm looking to swap out my ABS brake module. Mine has failed. Does anyone know if S80 and S60 are compatible on the 2005?
I see there is a 2005 S60 arrived at the local pick & pull.
2005 S80 ABS brake module
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
It will be compatible if:hu5ker555 wrote:Does anyone know if S80 and S60 are compatible on the 2005?
1 MY is the same
2 ABS type is the same (STC DSTC or TRACS)
3 Power train is the same (4WD or 2WD)
But if it is not compatible and programming is needed I would suggest using BCM from 2006 MY. They are a lot more reliable.
If you have questions about Volvo firmware ask me. I may know an answer
Elliot9874
- Year and Model: 2004 S80
I have a unused Volvo ABS module for sale let me know if you need it. The part number is 8671456
