Coolant bleeding
dubsetter
Year and Model: 1996 850
Post by dubsetter »
I recently replaced my thermostat sensor. After taking my 850 for a test drive afterwards, my coolant light started randomly flashing on and off sporadically (I figured I didn't clip the coolant reservoir sensor all the way in). When I pulled onto my street the light stayed on. When I got out I noticed I had lost a decent amount of coolant which came out of the thermostat housing. Luckily I was pretty close to home when the light started flashing on and off.
I ended up stripping one bolt trying to get the housing off. After finally drilling the bolt out last night, I found a small piece of plastic from a zip tie which fell on top of the gasket that I didn't see when I put the housing on.
I picked up a new gasket and volvo coolant and am ready to add coolant back in. I know the thermostat has a bleeder hole and I've read you should let the car idle for 10min to bleed the air out. My question is, do I leave the reservoir cap on or off(I read a forum where someone mentioned leaving the "cap" off)
Thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Leave the cap off; refill when the thermostat opens. Put the cap on and drive around the neighborhood. It may empty the reservoir again.
After ~2 fill-ups, you should be fine. Keep an eye on the coolant level (and possibly a jug in the car) for a week or so as it works the air bubbles out.
'98 S70 T5
2016 Chevy Cruze Premier
dubsetter
Post by dubsetter »
Great thanks! Unfortunately when I went to loosen the drain valve at the bottom of the radiator it snapped off. Ahhhhhhhhhhh!!! Since the valve is still closed, I guess I am going to drain from the lower radiator hose.
It looks like I will be able to remove the broken part stuck inside the radiator with a hex key(hopefully)
Has thanked: 1613 times
Been thanked: 4078 times
Leave that broken part in and epoxy it in place. Usually if you try to remove it you goober up the plastic threads and end up epoxyimg the hole anyway
