2000 V70 XC Can't fill gas tank
BrianV70
Year and Model: 2000 V70 XC AWD/SE
Has thanked: 7 times
Post by BrianV70 »
Hey, I'm new here, but I found you via Robert DIY who's videos helped me with a stuck door and a heater core. The MAN.
We just had our first cold snap here in Denver - below zero overnight. Don't know if that is related or coincidence.
1. I tried to refuel on a cold morning and fuel shot out the filler neck onto the pump.
2. After a warmer day (45 F) and some gas line antifreeze, it still takes about 15 minutes to add 2-2.5 gallons. I barely squeeze the nozzle and basically let it fill up the filler pipe and then drain into the tank.
3. I have a CEL. I will buy a code reader tomorrow to see what the code is.
4. There is a fairly strong whoosh or vacuum sucking air in when I unscrew the fuel cap. I've been driving without it in case it is putting strain on the fuel pump. (And we know that replacing a fuel pump in this car is either sending it to the crusher or cutting a hole in the floor.)
Seems to be running fine.
Help please! Where should I start?
Thank you
Background, not the focus of this topic:
How we ended up with this car is a loooong story, but we love Volvos.
We are the 4th owners. It has about 120K on the chassis and maybe a bit more on the motor. Our local shop has been over the car and overall thought it was in pretty solid shape except for some deferred maintenance. They had put a used engine in for a previous owner who had it towed in. Did a bunch of other stuff too including the RMS.
My wife is pissed because we just dropped $1300 on tie rods, sway bar links, and a drive shaft (prop shaft to rear awd).
Previous: SAAB 900 (gm edition) SAAB 9-5 Arc, Volvo 850 sedan in fall rust orange!
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
You have a tank vent that is stuck shut most likely. Search the repair database for a diagram of the EVAP system.
M1 10W-30 HM
BrianV70
Post by BrianV70 »
Thanks - I will look at those.
Update: Codes are P0446 and P0453
Replacing the purge valve might fix it?
Has thanked: 1610 times
Been thanked: 4069 times
Don't throw parts at codes, especially EVAP codes. The system is complex and knowing you have a stuck vent the system is not going to be happy
BrianV70
Post by BrianV70 »
Who knows if anything I did actually fixed this, but...
- A few warm days
- A bottle of gas line antifreeze
- Stuck an electrical fish tape down the filler neck until it hit something
- Blew compressed air through the filler neck vent tube and filter
- Zip tied the filler neck about an inch higher where it passes through the hanger on the frame. It seemed like there was a slight up hill slope to it.
Tank filled easily a couple of days ago and the codes have not come back...yet.
So now I've probably jinxed it.
BrianV70 wrote:Who knows if anything I did actually fixed this, but...
- A few warm days
As long as your zip tie colour doesn't clash with your car you should be good.
( satire)
