2006 xc90 wipers
cantgrumble
Year and Model: 2006 v70
Post by cantgrumble »
Help please...................Passenger side wiper has given up the ghost,well almost. It 'tries' to sweep but struggles and is ineffective. The other wiper is perfectly fine ........Any suggestions would be helful.
Thanks
cantgrumble
A new wiper motor or possible 'relay' change ?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
The fact that it tries to sweep leads me to believe it is not a fuse or relay. Make sure the nut (I think 10mm) that holds the arm on is tight. It is hidden under a black flap on the arm base (pry flap up gently from outer edge by hand or small screwdriver be careful not to break it off). If the bolt is loose the motor will spin but the arm itself wont be moving or will move but not complete a sweep.
wiper
wiper
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
cuhfs
Post by cuhfs »
Any resolution??? Please post.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Tighten the nut as above by cuhfs under the cover of the wiper arm. There is a spline there that can disengage when the bolt loosens.
cantgrumble
Spot on guys.....yes the nut was loose......Thx
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I usually add a drop of Loctite to prevent further issues.
Remove the nut.
Add a drop of Loctite.
Re-install the nut.
