2005 Volvo S40
ALL OF THE REAR TAIL LIGHTS are OUT except for the turn indicators which DO work.
The Reverse light is also OUT
WHAT WORKS?
The center-rear glass brake light DOES WORK
The license plate lights DO WORK
*The bulbs all appear fine- I could replace them all anyway but doubt all would burn out at once..
*I checked fuse #57 on mine (On-board computers, brake lights) -looks fine
*I checked fuse #79 on mine (reverse lights) looks fine
*I see no other fuse in owner's manual that seems pertinent but was planning to pull every one of them and check them out for the heck of it...
Any Suggestions on what to logically check next??
About had it with this car!!!!!!!!!!!!
Thanks in advance
2005 Volvo S40 - ALL Rear tail lights are out
MemphisSlim
- Year and Model: 2005 S40
- Has thanked: 17 times
- Been thanked: 35 times
That's a tough one...Anyone lend MemphisSlim a hand?
I was thinking multi-meter but if you get no juice to the rear anyway, I doubt that's where your problem is. Check fuses again. Use a meter on them? Sometimes fuses look okay and they're not. You are talking about the fuse box under the passenger foot-well, right?
mf70
- Year and Model: V50 2006
- Been thanked: 2 times
Have a look at the https://www.matthewsvolvosite.com/downl ... agrams.pdf wiring diagram. You may be able to see if the fuse is energised only when the lights are on. If so, you can check for voltage at the fuse block
- 3474 Views
Last post by BEJinFbk
- 1487 Views
Last post by deejaymo1
- 863 Views
Last post by alschnertz
- 3277 Views
Last post by ogatrulle
- 1474 Views
Last post by T64me
