Hi friends,
I have a '98 T-5 v70 and am about to clean the Throttle body. I picked up a gasket from o'Reilly and it is for the 2.4 liter engine which is the N/A engine. I know the turbo TB is different from the NA TB, but is the gasket different? I looked on FCP and noticed that the NA and turbo TB gaskets have the same part number which leads me to believe that even though the TB's are different the gasket is the same. Can some let me know if the gaskets are in fact the same?
Thank you for your help.
1998 T-5 throttle body gasket, same for turbo and NA, confirmed Topic is solved
- charleskennedy23
- Year and Model: 1998 V70 T5
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
- Been thanked: 4071 times
Lilse Volvo in Illinois has a great website with Volvo parts explosions and part numbers that will sort this out , Charles
- Has thanked: 2207 times
My version of Vida shows them as the same part # 9135990.
Neil
Neil
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Yes they are the same. The NA throttle body will have a perfect fit in the opening, the turbo throttle body will have inner metal exposed.
- rspi
Contact rspi..
The difference is the actual size difference between the two. That is why some people change to the NA throttle body as a mod for more intake air flow.
- charleskennedy23
Thanks guys! Robert I believe you talk about the that particular mod in your video which is why I wanted to make sure there weren't two different gaskets.
you guys are awesome!
Charles Kennedy
- 1874 Views
Last post by jreed
- 2284 Views
Last post by BeachWagon
- 6715 Views
Last post by pranayama
- 2611 Views
Last post by shaker_chi
- 36 Replies
- 5860 Views
