Couple of notes on this job
Pop out the speakers, then remove the electrical sockets from the lens, depressing tab, then pulling white connector forward
There are four 10mm M6 nuts holding on each lens (one up high, two amidships, one low) , they are on long studs so you need a deep socket or a 'longer' socket to get to them. A speed tool is really nice You reach them through holes in the metal frame
There is special place to collect dropped nuts and sockets down low - stuff a rag in there before you start work. I managed to fish them out with a magnet
The top lens comes off first and snaps into the bottom lens - if you pull the bottom one off you break the top one, or both.
P80 Wagon Rear Lens assemblies Removal
- 1980 Views
Last post by CarCapers
- 1099 Views
Last post by XCfella
- 441 Views
- 1246 Views
Last post by chrism
- 2230 Views
Last post by sleddriver
