No Start possibly due to bad PNP?
kashee77
Year and Model: 99 V70 XC Turbo
Has thanked: 2 times
Post by kashee77 »
Hi
I have 98 v70 base model with a no start issue, sometimes it starts sometimes it doesn't, combined with a flashing winter driving mode button down on the gear shifter trim. Today it started and the winter driving mode button stopped flashing. At first I thought it was a starter issue but now I'm wondering since the PNP switch acts like a neutral safety switch (among other things) is it possible that it is causing the no start. Also how do you get to the PNP Switch?
99 V70 XC
98 V70 XC (Parts Car)
previous
99 V70 XC (Parts Car)
96 850 Turbo
95 850
95 850
88 740 had 466,000
I am a bit of a fan
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You are on the right track. My Platinum has a bad PNP and about 5% of the time the starter doesn't work until I row the shifter and sometimes I have to go to neutral. The flashing up arrow is also typical with a failing PNP switch.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
kashee77 wrote:Also how do you get to the PNP Switch?
It's right on top of the transmission.
https://www.matthewsvolvosite.com/forums ... =1&t=29930
Has thanked: 1611 times
Been thanked: 4074 times
Search the remote starter connection thread to find the bypass connector.
That is a quick test of the starter cable battery side of the circuit, plus it can bail you out when you are on the road
