2002 V70 Xc with the ECC system. When I scanned the car- I got a code for heated seat switch intermittent.
Can you replace the switch on cars with ECC or is it part of the panel?
If you cant replace it is there a way to wire around it?
Its 7 degrees in Illinois and my butts cold....
heated seat not working drivers side
- Been thanked: 4071 times
Switch pops out from front of panel once you get access , but check for voltage at seat plug to confirm diagnosis before throwing parts
