Upper torque arm head support broken Topic is solved
caltemus
Year and Model: 1994 855 NA 5spd
Has thanked: 1 time
Post by caltemus »
Hey all, the pictured part broke pretty violently on the highway, causing the whole torque arm to rattle around and the engine to shake in the bay. The two larger (13mm?) bolts holding the arm to the block were also loose. What is it called and where can I get a replacement? Luckily I was able to pull one off of my spare 850 but I'd like to buy a backup. For reference; it's a 1994 850 NA 5-spd, and the one on my 1995 NA auto was the same part.
Thanks,
-Charlie
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
This seems to be the part you're looking for, #26 in the diagram:
It is part number 9434264, called "Stay." Check out FCP Euro or the dealer. I got the diagram from Volvo Parts Lisle, and they have the part available as well.
caltemus
Has thanked: 1 time
Post by caltemus »
Thanks, I've ordered 26 and 28 pictured for 14 dollars shipped. Good thing i had lawnmower syndrome or I wouldn't have caught this so soon.
bmdubya1198
Very good! Not a bad price either!
Has thanked: 2202 times
Been thanked: 1852 times
I can't see all of the upper torque bush, but it does not look like it is fitted correctly. I would have expected to see less of the bush than this appears to show. I'd have a close look at the bush relative to the spare one you have.
Neil
bmdubya1198
scot850 wrote:I can't see all of the upper torque bush, but it does not look like it is fitted correctly. I would have expected to see less of the bush than this appears to show. I'd have a close look at the bush relative to the spare one you have.
Neil
Good observation. It doesn't look like the correct position for a stock bushing. I have a poly bushing, but it fits a bit too sloppy for my taste and I think I'm going to change it back depending on if the vibration goes away after replacing my hydraulic motor mounts. Mine probably has about the same amount of play as in that picture.
caltemus
Has thanked: 1 time
Post by caltemus »
When I first got the car, the torque arm bushing was shot. Rather than deal with press fitting a new one, I bought the assembly from FCP (Torque Arm Bracket With Bushing - Pro Parts Sweden 3524345). It has always had some play between the bushing and bracket. It was also below freezing when this photo was taken. I'm actually pulling the whole bracket to the right in the photo to show the broken piece better. I did re-center the bracket on the bushing when i was buttoning everything up. Would there be any problem putting some blue loctite on the large lower bracket bolts, to try and prevent this in the future?
bmdubya1198
I don't see why you couldn't use Loctite. As long as it isn't a permanent type thread sealer. I've heard horror stories about that being used on the VVT cam bolt and it not being able to be removed.
+1 on the none permanent thread locker.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
caltemus wrote:When I first got the car, the torque arm bushing was shot. Rather than deal with press fitting a new one, I bought the assembly from FCP (Torque Arm Bracket With Bushing - Pro Parts Sweden 3524345). It has always had some play between the bushing and bracket. It was also below freezing when this photo was taken. I'm actually pulling the whole bracket to the right in the photo to show the broken piece better. I did re-center the bracket on the bushing when i was buttoning everything up. Would there be any problem putting some blue loctite on the large lower bracket bolts, to try and prevent this in the future?
I had problems with Proparts arm and bushing set, too. It slid around too much and caused so much engine vibration. I couldn't for the life of me understand why an engine with all new mounts all around rattled like my beater, a 99 Altima. I ponied up and just bought the OEM bracket and bushing and it really smoothed out my engine... I
wonder if all that extra vibration from the poor fit of the bushing led to this stress fracture.
Retired:
2015 Volvo S60, T5, 85K
