Hi,
So I recently got Zimmerman rotors and Akebono ceramic pads as this was the recommendation from members of the forum. I notice that when I first use the brakes in the morning or after the car sits for a bit that they squeal. It is only when they are first applied though. Has anyone had a similar experience? Does anyone know of a solution?
Thank you.
1996 850R Zimmerman Rotors and Akebono Pads
- chrafael
- Year and Model: 1998 v70 GLT
- Been thanked: 10 times
Yes, exactly. If I lightly drag the brakes for a few feet it goes away for a few days. I chalk it up to morning dew on the rotors or the pad shims not quite doing the job. Premium brake grease on the appropriate parts didn't seem to change anything.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Most common noise comes from the rears. It is important to use the squeal shims. I have that combo on 2 cars with no noise.
- chrafael
rspi is right, the noise is coming from the rear. It's just so slight it's not been worth taking apart to correct. If I remember correctly, don't the Akebonos come with shims? What would I do? Reglue them? Also, my rotors are OEM resurfaced so I don't think that is part of the problem.
- 3159 Views
Last post by Scholz
- 780 Views
Last post by oragex
- 906 Views
Last post by regent
- 2255 Views
Last post by fishingdad101
- 967 Views
Last post by Idigbebop
