2004 XC70 braking warning light on cold start Topic is solved
mchaggis
Year and Model: 2007 C30
Post by mchaggis »
hello,
I have a brake warning light appear on cold start up but disappears after 20 minutes of driving. Any recommendations on how to address the situation?
New to Matthews and my first used XC70.
Cheers,
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Check brake fluid level in master cylinder reservoir. The buoyancy of the float in the brake fluid increases when it warms in engine compartment. When the level is right on the threshold of warning it will do what you experience. Usually brake fluid can get that low from pads being worn down to the lower limit. If pads are ok then expect to find a leak somewhere.
mchaggis
Post by mchaggis »
Thanks, Sounds like that is the issue. I was just informed both front and rear pads are done and need replacing.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Takes only Dot 4 synthetic fluid for European cars. Canadian tire has it in Certified brand.
