CEL comes on periodically with these two codes. Then it goes away, then comes back. Car is running OK, steady idle, good power.
Suggestions? I already cleaned the MAF, but the codes eventually come back.
P0101 and P2188 codes
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
What car is it?
Cleaning MAF does nothing, you need a new one. Car runs fine, because ECU sees it can't rely on MAF sensor reading and switches to preprogrammed values. It injects more gas to keep cat.converter cool.
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
Sorry...2005 S60 2.5T
Do I need a special tool to remove the security torx screws?
Any suggestions on where to get a new MAF?
My next step was to smoke test it with a cigar.
vtl
https://www.fcpeuro.com/products/volvo- ... 0280218088
or, if you like blue boxes
https://www.fcpeuro.com/products/volvo- ... 0-31342414
You can also start with a used MAF.
A hole in intake would cause an uneven idling and a LEAN fuel mixture.
hu5ker555
Thanks for your responses. So, a P2188 code would not be caused by a vacuum leak?
I saw some MAF's available on ebay for about $20. Maybe I'll start there.
Could it be a dirty throttle body?
