c30 firing order
I have a 2008 C30 and a check engine light is on! The code shows cylinder misfire in #1 and #2 cylinders. I am going to replace the coil pack and plug for these 2 cylinders(I cant afford to do the rest). Can some please tell me which cylinders are 1 and 2 ? Thanks
- Has thanked: 17 times
- Been thanked: 35 times
1 is closest to the passenger side...where the timing belt is and the count-off is from there, towards the driver's side..1,2,3,4,5.
Yes, that is the correct order of the cylinders although firing order is not the same thing. It actually fires in this order: 1-3-5-4-2. But the cylinder numbers are as I posted them. If in doubt, change the 2 out that you bought coils for and see if the misfire codes are still there... I'll bet they'll be gone now. You can also put the supposedly bad coil on a different cylinder to see if the misfire follows to the different cylinder.
- 6282 Views
- 2871 Views
Last post by tomcruiise
- 11 Replies
- 1967 Views
Last post by plumsmooth
- 8801 Views
Last post by erikv11
- 1460 Views
Last post by oragex
