Hello to all,
Today i buy my s80 t6 with gearbox problem.My question is,can i use gearbox from 2.9 non turbo?I know that t6 is geartronic,and 2.9 is not but is there some how i can use this gears.Sorry for my bad english!
2001 s80 t6 problem
- KobeBryant
- Year and Model: 2001 S80 t6
UncleBoost
- Year and Model: 855 R, 1996
Ditto... Either get yours rebuilt by triple edge or roll the dice (take a chance) and buy a used gearbox from a preferred rear ended wreck.
- KobeBryant
So i have gearbox from 2.9 that i can't use...that's nice
precopster
- Year and Model: Lots
- Been thanked: 128 times
Technically they both use the GM 4T65 transmission however the final drive ratio is different from the turbo to the non turbo.
Ratios vary as per this table:
Automatic transmission
Gear ratios:
Engine: B 6284T B 6294S
1st gear 2.92:1 3.27:1
2nd gear 1.57:1 1.76:1
3rd gear 1.00:1 1.12:1
4 th gear 0.70:1 0.79:1
5 th gear
Reverse 2.38:1 2.67:1
Final
drive 3.29:1 3.69:1
Gear ratios:
5 th gear
Final
drive 3.29:1 3.69:1
- KobeBryant
What is the problem with the ratio?Low max speed.Main problem is with the control module i think.My ECU will not read the 4T65EV.
precopster
ECUs don't read the transmission. They read the speed sensors and any other sensors that report how fast the car is going relative to engine speed.
If the speed sensors report a different road speed relative to engine revs than your car is meant to report you will get transmission fault codes and the car will go into transmission limp mode.
You could try the S80 non turbo TCM (trans control module) The car may work fine when paired up with the correct transmission.
- KobeBryant
The best thing to do may be to rebuild my transmission.
precopster
Yes apparently many of the repairs on this transmission can be done while it is still attached to the car. You could look up here and on Swedespeed as there are many tutorials about this topic.
- KobeBryant
Where i can buy the parts?I'm from Bulgaria and here i don't have many options.Tere are no rebuild kits here...
- 1165 Views
Last post by SJLucky
- 773 Views
Last post by rdklxprs
- 1909 Views
Last post by volvolugnut
- 735 Views
Last post by Synergychaz
- 1560 Views
