After-market stereo
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If you have the base HU-600 unit, I'd suggest a try for the HU-800. Used is under $50 at breakers, coupled with the 300W amp + cable it is a serious improvement, even with the base speakers (the premium door tweeters are easy install and worth the upgrade). I put a 2004 HU-800 in place of my 2003 HU-600 and I have everything functional as before (no programming), so matching the years can help having full functionality. Side note, the HU-800 is prone to skipping (worn internal dampers) and eating CD's
We'll I really have no need for CD player. I'm looking for something that is Bluetooth capable. I'm thinking about buying this- http://www.crutchfield.com/p_130290BT/P ... ml?tp=5684 - but I'm worried about the central computer throwing fault codes...oragex wrote:If you have the base HU-600 unit, I'd suggest a try for the HU-800. Used is under $50 at breakers, coupled with the 300W amp + cable it is a serious improvement, even with the base speakers (the premium door tweeters are easy install and worth the upgrade). I put a 2004 HU-800 in place of my 2003 HU-600 and I have everything functional as before (no programming), so matching the years can help having full functionality. Side note, the HU-800 is prone to skipping (worn internal dampers) and eating CD's
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It will permanently store DTC that CEM is unable to communicate with AUM, but you won't see anyseen annoying on the dash.
You will loose steering wheel controls, parking sensors (if any), volume vs speed adjustment, automatic dimming, but you can also buy an adapter to solve these issues.
This is what I have in my car:
All works, plus I have a rear view camera now
vtl
Yes: https://incartec.co.uk/Pages/Product.aspx?P=3400AlanS wrote:Is there an aftermarket product that will return the parking sensors with an aftermarket radio? I lost mine when I removed the Volvo radio.
vtl
https://www.matthewsvolvosite.com/downlo ... iagram.pdf
Page 89
Group 37 Wiring and fuses
Diagnostics system
Pins
3 - LS CAN-H
11 - LS CAN-L
6 - HS CAN-H
14 - HS CAN-L
Page 89
Diagnostics system
Pins
3 - LS CAN-H
11 - LS CAN-L
6 - HS CAN-H
14 - HS CAN-L
The product (that you recommended) only indicates that I need to activate ground, power, CAN high and CAN low data wires. Since I am going to do this myself, I need to be very careful about what I attach things to!!! I assume that the green AUM connector is the one in back of the radio? I don't know the difference between LS and HS... There is a pic on the distributor's website. https://incartec.co.uk/Instructions/25-514(1).pdf I need to know if that pic is the green plug you speak of...
- 1123 Views
Last post by tryingbe
- 751 Views
Last post by mayorpeoria
- 523 Views
- 797 Views
Last post by Manning
- 1082 Views
Last post by wizechatmgr
