Code 0034 SIPS driver's seat airbag failure
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
My DIM showed an 'SRS airbag warning - emergency repair'. Code reader showed 0034, driver's seat airbag resistance too high. My wife told me this appeared after she had reclined the (power) seat all the way to take nap. Checking online and here I found possible causes were a cut wire, loose connection or a failed airbag. After checking and replacing a section of wire that appeared damaged, the code persisted (I could clear it, but it would come back after 5 seconds). Finally replaced the airbag itself today with a used one ($20) and presto, after clearing the code it did not re-appear. It was a bit of work to remove the seat, remove the cover (lots of hog rings etc) and figure out how to put it all back together (lots of tie wraps to replace the hog rings) but it's one of those satisfying repairs. Hope the replacement one lasts for a couple of years.
