Wet floor again.
I found the source of the leak (2006 xc70) but not the reason. Water is leaking from the cabin filter chamber on the pass. side. If I were to open it up, a nice amt of water would exit. I originally thought it was the cowl drains, as this is what happened to my 850...I kept them clean, rain today in NY...water dripping from the cabin filter housing. Any ideas?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There's about a dozen of 'sources' actually. May have a search on Youtube. Here's just one of the vids
The bottom cover of the cabin filter is made of plastic and has a small rubber seal around. The plastic bends with time, I'd suggest replacing this cover if available at the dealer. Myself I've used some silicone but it's harder to remove the next time.
Also, I'd inspect the drain tube from the cabin blower unit - same place but near the right wall. The rubber tube goes into the wall and exists, can be removed and cleaned at the bottom end. I'd also make sure the blower has all it's mounting screws properly secured - I believe 5, one of which is located almost behind the blower.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
I'd pull cowl out to inspect under it and they sunroof drains have been known to make a puddle on floor. A friend on mine had an '04 XC90 that leaked due to sunroof drains and fouled up a couple of modules /harenes which would cause his XC90 to go into limp mode. He would turn her off then restart her to reset computers but he procrastinated to bring her in for diagnostic and burned out his trans constantly driving in limp home mode.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- 612 Views
- 23 Replies
- 4897 Views
Last post by rguzz
- 1014 Views
Last post by AlanS
- 2404 Views
Last post by RickHaleParker
- 1021 Views
Last post by Skymongrel
