hi guys
I own a 244GLE, B23A, with a Zenith Stromberg 175 CD-2 Carburetor that needs a rebuild.
I found this Brand New Zenith carburetor 175 CD 25 (originally fits Land Rover 6 cylinder). its a good price, and want to buy it for my 244 instead of rebuilding my old one.
see here:
Brand New Zenith carburetor 175 CD 25 Land Rover 6 cylinder maybe Triumph rover | eBay
I was told that it would fit well, but still have some doubts.
What do you guys think ? would it fit my 244?
Default a new Carburetor for my 244GLE, B23A Topic is solved
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
I'm not familiar with these sidedraft carbs, but if cfm (cubic feet per minute) were different on both engines, then it may run rich unless rejetting can be done, if this is the case.re_ilan wrote:175 CD 25 (originally fits Land Rover 6 cylinder)
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
re_ilan wrote:sory, I don't anderstand the quastion. what linkage might be needed?lummert wrote: Can you make the changes to the linkage if needed?
The linkage lever on the side of the carburetor. It's held on with a nut.
1988 Volvo 760 Turbo Wagon
claymore850
- Year and Model: 850 T5, 244, V70 2.4
Hello im working on same conversion...found a NOS Zenith stromberg at ebay from a Rover too.
You must change accelerator linkage side...remove copper pipe (use a 3/8 drill) and a vise grip..to prevent deformation,, it allows you to remove without damage.
Today i will install and test..but im sure that mixture will be too rich.. (rover is 2.6L).
check this pictures,..will help you maybe..
regards
Rodolfo
Guatemala, Central America
regards
Rodolfo
- 20170211_081708_resized (1).jpg (157.93 KiB) Viewed 2727 times
- 20170212_220720_resized.jpg (170.72 KiB) Viewed 2727 times
- 20170213_080604_resized (1).jpg (162.98 KiB) Viewed 2727 times
- 20170213_080557_resized.jpg (180.02 KiB) Viewed 2727 times
- 20170212_163114_resized.jpg (185.14 KiB) Viewed 2727 times
- 93Regina
If there is an available vacuum port on intake manifold, one might attach one end of a rubber hose to this vacuum port, and the other end to a gasoline filter, like a Fram G1000. Ideally, the vacuum port would be in a central location.claymore850 wrote:im sure that mixture will be too rich.. (rover is 2.6L)
lummert
Maybe the metering rod and/ or metering jet can be swapped over from the original carb. British Leyland tuning guide shows a main mixture adjustment under the plastic cap.claymore850 wrote:Hello im working on same conversion...found a NOS Zenith stromberg at ebay from a Rover too.
regards
Rodolfo
- 1307 Views
Last post by jfxavier
- 25 Replies
- 7184 Views
Last post by speedyt5
- 733 Views
Last post by outrigger777
- 731 Views
Last post by oragex
- 5964 Views
Last post by chrism
