Hi, I have a " TIRE PRESS SYST SERVICE REQUIRED" error message on a 2009 S40. I also have a 2006 S40 with no TPMS errors, so I was wondering if I could take one of the 2006 wheels off, and try one wheel from the fault-giving 2009 at a time on the 2006 to see which of the sensors from the 2009 is bad?
I also have the VIDA software if that could potentially help me clear the code or get to the bottom of which sensor is bad or needs reprogramming, but thus far I haven't been able to solve the problem with it.
Any advice would be appreciated.
Thanks.
TPMS diagnostic trick?
- Has thanked: 17 times
- Been thanked: 35 times
As my car does not have TPMS, I really can't answer you on this one. You might just try calling the dealer. If they are nice enough they should let you know if the 2 car's systems are interchangeable or not. I wouldn't tell them you're trying to DIY or they may withhold info from you and try to get you go come in.
- 1339 Views
Last post by Georgeandkira
- 2384 Views
Last post by RickHaleParker
- 540 Views
- 1454 Views
Last post by erikv11
- 1730 Views
Last post by JakeNZ
