Hey Guys, sanity check please.
Wife's car, I did the PCV kit replacement around 1.5-2 years ago I think.
I'm now getting a CEL, and pulled codes PO101, PO170. Car running fine.
I think these were the same codes I got when the PCV was full of sludge last time.
The car chews through a lot of oil, in my mind, but I have not quantitated.
So I'm thinking it's full of sludge again.
I guess my plan was to tear it down and look...if that is what it indeed sounds like to the forum.
Can it happen again so quickly and is there and option to just replace the black box and clean, without doing the whole kit...I remember that line being a PITA.
Would you look a anything else first?
CEL -Suspect PCV Again
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Wondering, did the oil passage inside the oil pan check clear when the pcv box was out?
Short driving distances is what clogs the pcv system the most, even synthetic oil is not a 100% fix
Crumpler
- Year and Model: XC70 2006
- Has thanked: 2 times
My memory is that it did. My recollection doing the pcv box was that it was about 80% occluded where it meets the block.oragex wrote:Wondering, did the oil passage inside the oil pan check clear when the pcv box was out?
The only thing I did so far was drain about a quart of oil off the car. I found that the oil had been over-filled some what.
I erased the codes and they have not reproduced with normal driving. I vented the dip stick slightly.
I have not had a lot of time to research the concept, are there any credible after market vent systems, NA v. turbo?
Dave
2006 XC70
132,000 miles
2006 XC70
132,000 miles
- 5163 Views
Last post by LT South Africa
- 13 Replies
- 12208 Views
Last post by SVO LOU
- 1855 Views
Last post by kaneelschep
- 1361 Views
Last post by hamiltoncj76
- 1120 Views
Last post by misha
