Looking to purchase round 2
olszewskisp
Year and Model: 2002 S60
Post by olszewskisp »
I found a 1999 Volvo s70 I am very interested in.
http://seattle.craigslist.org/see/cto/5927307175.html
The car turns over and has a new belt and water pump. Is it worth it? If so how much would a fix for this be? I understand there can be a lot of variables. Best guesstimates would be much appreciated.
Has thanked: 1609 times
Been thanked: 4065 times
For sale is a 1999 Volvo S70 T6 with Turbo. Needs timing corrected. A friend gave this car to me when he couldn't figure out what was wrong with it. Had a blown head gasket. Paid a mechanic to fix it, and he machined the head, and replaced the head gasket and fuel pump, then disappeared. He never corrected the timing, so the car won't run. It has been sitting in my driveway for 4 months, and I just want it gone now. Should run just fine If you have your mechanic do the adjustment. I am looking to get $700 out of it, even though I know the parts alone are worth $3k or more. Time to move on. It has:
Clear title, with tabs good until 12/16
4 good wheels/tires
new fuel pump
new head gaskets and head machined to spec.
all leather interior
sunroof
power windows/doors
power driver's seat
heated seats
cold weather driving setting
AWD
4 wheel disk brakes
keyless entry
Car has great acceleration and handling, and a quiet smooth ride. IT IS NOT CURRENTLY RUNNING, so you will have to tow it to your shop/home/?? I am firm on the $700, so please do not waste either of our time asking to buy it for less. Not interested in trades.
Please email or text only to show contact info
Randy
Thats a car that needs major repair that the seller can't afford and is spinning a story to unload it. My guess is he bought it to flip and is underwater
Pass.
bugs11
Year and Model: 850 1996
Post by bugs11 »
"Needs timing corrected." ??? The way I understand it if the timing isn't right the engine is fubar; valves would be hitting the cylinder heads. Could always put a replacement engine in it.
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Timing corrected? In other words, I #%#!#^ up and now the engine is shot. I want to unload this car because I have no idea what I'm doing and it needs a new motor. PASS on this one.
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
Yep the motor is more than likely toast but is the rare t6 s70
Not as rare as my V8 T5 V70 but that's just a brag.....
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
In addition to all that's mentioned above, the AWD system more than likely will need some attention, and the AWD on these cars is costly to repair/ maintain. It looks like a mess, so I would pass.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
olszewskisp
Cost estimates?
skloon
Post by skloon »
How long is a piece of string ? Minimum a timing belt so 400 or so but I suspect the timing went awry so a new head, maybe it messed up the block so another 1800 for used parts then you get it moving and figure out what else is busted much better buying one that runs and drives for 2000 and do the deferred maintenance from then on
