Hi guys, first time poster. Seems like a good community here, appreciate any help i'm given. Thanks!
So i've had a brake fluid light coming on once ever 2 months or so, i've been topping off with fluid and reducing brake use, gearing down more. I never have seen evidence of a leak no fluid on wheels or spots where i park. Just he other day i got in my car to go to work. Clutch basically goes to the floor, very little resistance and it doesn't come all the way back up, just a couple of inches return. Trying to leave work that day, and i can't get into gear at all. I looked under the car and the small white cylinder under the dash has fluid dripping from it, there is also fluid that has apparently beeb leaking for a while from up under the dash, not sure if it's only this little white cylinder or not. I've attached some pictures, any ideas?
Clutch not engaging, brake fluid low light
aspireToRepair
- Year and Model: 2009 C30
