My Volvo started dieseling last week. I did some research and I found a few possible causes, but I'm looking for advice on where I should start. I'm a novice (though, I'm proud to say that I have accumulated quite a few successful auto repair projects under my belt!) so any help is appreciated, as I'm also broke and need to DIY this thang.
It only runs on for a second. At a stop, it idles between 600-750 rpms. It has never stalled. No dashboard lights are shining, but about 6 months ago I brought it it for a transmission service (maintenance only) and the mechanic noted two error codes: fuel level sensor and MAF.
It's a turbo engine. 150k, with 5k on a rebuilt. It has been super well-maintained.
I have read that I could try putting Sea Foam into my gas tank (but to then be ready with a new fuel filter). Would this be a good place to start?
2005 S60 Run-on issue
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I don't think sea foam is a miracle product or anything that would fix a faulty gas pump or injectors.
Is the gas tank full? If not, I would start by verifying the fuel level, the level sensors are well known to show more gas that it really is.
