My 1995 T5-R check engine light came on so i had it read at Advanced Auto, they said it was "bank 1 rich". I cannot figure out what that means.
Also, for some reason my service light on the dashboard came on and is flashing. It comes on when it is due for service, but has never flashed before. What does that mean?
Engine code
You should always get the 'P code' not the description. since the descriptions are often wrong.
You want the data in format P1234, P followed by four numbers.
If this is right, its usually means you are getting excess fuel somehow - perhaps a faulty Fuel pressure regulator, but there are many causes to explore.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Bank 1 rich can be anything(from vacuum leak to o2 sensor).You must demand particular code in P format or Volvo code from Advanced Auto...OR...since it's '95,you have diagnostic ports under the hood.Read the codes yourself and post 'em here.
About service light flashing....i think that your instrument cluster is going bad....and you can also read the codes yourself.
http://volvospeed.com/volvo_repairs_how ... es_a2.html
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 316 times
- Been thanked: 531 times
So you're running rich... check for vacuum leaks at the easy-to-see hoses. Check the TCV hoses and purge valve hoses for cracking or obvious tears. Also check out the corrugated part of the intake hose to the turbo... it's possible that it is torn.
Cincyken
- Year and Model: 1995 850 T5-R
Would not a vacuum leak result in too lean a mixture. Why would a vacuum leak result in a rich mixture? I have never seen a 2-3-2 code before on any Volvo i have owned over the years.
- misha
Ecu enriches the mixture to compensate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Does the 1995R use the vacuum operated fuel pressure regulator? Thats a common failure point to check.
- misha
Yes it does.It's vacuum line could be the suspect.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Unless you have had very bad luck there are dozens of codes you've never seen pop up on any of your Volvos.Cincyken wrote:I have never seen a 2-3-2 code before on any Volvo i have owned over the years.
- 93 Replies
- 28656 Views
Last post by foggydogg
- 25 Replies
- 5834 Views
Last post by Gerd
- 1939 Views
Last post by RickHaleParker
- 23 Replies
- 4724 Views
- 1830 Views
Last post by Vova585
