2001 C70 convert 160K miles Just had cam seal let go and it spilled 5 quarts of oil around the timing belt and serp belt area. Will dig in and replace the cam seals and I am assuming I will need to do PCV system due to pressure build-up, and new belts due to oil drenching them.
Does anyone here flush their pcv oil trap #1271988 and special hose #9470330... (see pictures of parts I am referring to) with gunk or brake fluid and reuse these parts? Thoughts?
2001 C70 PCV Question
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
- Tasca part.jpg (15.92 KiB) Viewed 479 times
- Tasca oil trap.jpg (41.63 KiB) Viewed 479 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
I would reuse the trap after cleaning, but replace that hose. They get brittle and plugged and I think replacement is smart.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I usually flush those two parts. The kits sold through Volvo suppliers should have all of the other parts you need.
- rspi
Contact rspi..
I would NOT assume the system needs serviced unless you have blowby. In that case, do a compression test before tearing into the PCV. Sometimes seals work themselves out without the PCV being bad.
The plastic vacuum hose on the later PCV is really easy to break on either removal or install. At least have the part in hand when you do the job so you don't get stuck.
cuhfs
Thanks guys. You're the best!
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 387 Views
Last post by buschman
- 1250 Views
Last post by RickHaleParker
- 449 Views
- 636 Views
Last post by gkrogman
- 1646 Views
Last post by rspi
