Hi.
I have a '96 850 turbo w/ 185k miles on it. I've owned it for the past 5 years.
Long story short: the oil light didn't come on and when it should have. (The lamp in the dash is ok.)
I drove home from work on Friday (20 miles) - I heard a rattle when I started it at work (but didn't think too much of it) - I didn't hear it on the way home until I pulled into my drive way. Turns out the engine was low on oil, and now it has a rattle. Today I changed the oil and filter, but it made no difference. I have not checked oil pressure.
So, what do I do to fix the rattle/knocking? Change the lifters? Clean the oil intake? Shoot it between the eyes?
(I really like this car. I am a bit distraught at the moment...)
Thanks for any input/thoughts/advice...
Splats.
What's worse than the engine oil light coming on?...no engine oil light.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Man, sorry to hear about this. Just curious, how low did you let the oil go?
Retired:
2015 Volvo S60, T5, 85K
You should be ok.
If it's lifter rattle ( continuous) drive it for a bit and see if it improves. You really should use synthetic if you aren't.j
If it's a rod knock ( loudest when you lift foot off gas) drive it locally only and avoid high speed /high revs
When it goes to tock or thunk...its decision time
splats
- Year and Model: 1996 850 Turbo Wagon
Thanks for the advice, Abscate. I'll try your suggestion. The rattle is continuous at idle. I don't notice it getting louder when I take my foot off the gas. And I'll switch to synthetic on my next oil change.
Thats good. Worst case maybe some new lifters, maybe even avoid the whole clip of bullets if you have been living life with a full karmic bucket.splats wrote:Thanks for the advice, Abscate. I'll try your suggestion. The rattle is continuous at idle. I don't notice it getting louder when I take my foot off the gas. And I'll switch to synthetic on my next oil change.
splats
abscate, you were right. I drove around for 15 or 20 minutes and the rattle has pretty much disappeared (completely, even?). I'm going to let the engine cool down to see if returns.
(I'm waiting to find out, but the karmic bucket may have been filled in my favor when I had to change the heater blower motor in my '89 240...)
- 1445 Views
- 13 Replies
- 2354 Views
Last post by Sommerfeldt
- 381 Views
- 13 Replies
- 5483 Views
- 2802 Views
Last post by dscheste
