Signs of transmission getting tired? XC V70 1998
schuckles
Year and Model: XC V70
Post by schuckles »
Hi,
My Vol just passed 200,000 miles. I've taken insanely good care of it, don't use the turbo too much, get it serviced by a seasoned vol tech when the service light goes on. She's been OK. Had issues on the way to Tahoe, had the altitude sensor replaced, but I digress.
The transmission in this car has always, sort of, shifted a little 'rougher' than I'd like. Like, at times in stop and go traffic, the transmission will slip into 3rd gear as I brake to anticipate California 101 traffic BS. My car is currently in the shop for an unrelated issue and using a non turbo loaner. The loaner's transmission seems smoother, but on the other hand, it seems to exhibit some of the same harsh shifting. A good example is the locking torque converter, in both cars when cruising at 62 MPH, as soon as I let off the gas, both transmissions seems to loose their lock and after a few miliseconds, the lock engages and the RPMs dip slightly.
Is it me? Should I shovel money away for a new tranny?
Thanks,
Jon
Has thanked: 1609 times
Been thanked: 4064 times
An AT trans swap isn't too bad if the rest of the car runs well. Have you be en draining and refilling fluid on a regular schedule ?
No " power flushes " for an old car. Keep it simple
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
When was the fluid last changed? I initially did about 3 "drain & fills" and put a Magnefine inline filter on mine. I do a drain/fill about once a year now.
I highly recommend putting in Mobil 1 Synthetic ATF. It's pricey (look for sales or Amazon prime it!), but my car is closing in on 250K and the transmission (appears) to be just fine. Every once in a while I do experience a wonky shift, or a little clunk if I let off the pedal while accelerating hard. It's been doing those for over 100K since I've had it though.
I hope yours is fine!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 2197 times
Been thanked: 1851 times
Try a drain and fill like the guys suggest. If it has not been done recently then it is way over due. I also get some rough shifts on 3rd but I have a 5-speed auto, but it improved after a fluid change. The drain and fill over 3 engine oil changes should make a big difference.
Also check the engine torque mounts for wear and the engine pad under the crank pulley. Those also can aid with rough shifts.
