2002 S60...Other 3 windows work, cleaned switches and PC board at master panel located on drivers door.
I dont hear the relay click for the stuck window but I do hear the click for the rest...I just cant find them.
Does anyone have any suggestions or is able to tell me where the relays for the windows are located??
Thank you!!
passenger side window has fallen and cant get up
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How is the fuse in the left side dash fuse panel?
Thanks for reply Oragex,
I've tried the fuse, it looks good and swapped with a known good to confirm.
I noticed all other switches on the master are lit with the exception of the inoperable passenger window. This is why I was thinking relay but I'm not even sure if such a relay exists!!
It wasn't responding from the passenger side switch either.
I got it moving again by removing the switch and took it apart to clean out the guts. So ultimately it was just dust and dirt accumulated over the last 15 years.
... now its on to the front strut!!
- 1079 Views
Last post by Georgeandkira
- 966 Views
Last post by kuuze
- 11 Replies
- 1231 Views
Last post by mecheng
- 11 Replies
- 1780 Views
Last post by ibs740
- 1295 Views
Last post by Vovo_merz
