1999 V70T5M Nissens Radiator Replacement Drain Valve
Has thanked: 1609 times
Been thanked: 4063 times
OK - who can tell me what is going on here ??
It turns 1/4 turn, does not come out.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Leave it in, don't touch it. Drain the radiator by removing the lower radiator hose.
85 GLH, 367 whp
00 Insight, 72 mpg
dyn blin
Year and Model: 1997 850 Wgn
Has thanked: 1 time
Been thanked: 2 times
Post by dyn blin »
I've got a shop drawer full of them for when I inevitably strip them.
Lower hose is the way to go for draining as long as you don't have those shrink-fit hose clamps.
'97 850 GLT Wagon- Driving to see 300k in the rearview
I've been draining by the lower hose for a long time. I was just expecting to see the usual drain plug.
EstVolvo
Year and Model: 2000 V70
Post by EstVolvo »
Yes it turns and then it comes straight out.
Yes it does, it just needs a firm tug.
Thanks belatedly, ESTVolvo
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
I recently installed a similar radiator and had the same question. Pulls straight out after the quarter turn. My fear was that it would easily unlock a quarter turn and push itself out under pressure. Over the last 4k, that has not been a problem.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
You could easily drill the tab and zip tie it to the hose flange, but I think that is bordering on the paranoid
