Hey Folks,
I noticed that my Volvo has a hard time starting in cold days after being parked for a while or over night in the morning. I have to crank it over a few times. Any suggestions are most welcomed.
Thanks.
2004 Volvo S60 150K miles cold weather starting
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
Runs ok after it starts? Do you see the tach bounce around at all while it's trying to start? Might just need a battery refresh. You can maintain batteries by adding distilled water to each of the cells.
viewtopic.php?f=9&t=73914
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
zanzabar
What kind of battery is it? Can you list the exact brand and model? Possible that it doesn't have quite enough CCA?
If you can verify that the battery is fine, then start looking into general tuneup stuff: spark plugs, air filter, fuel filter, fuel system/injector cleaner, etc.
Any stored diagnostic codes?
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
Matt2008S60
- Year and Model: 2008 S60 2.5T
zanzabar wrote:Runs ok after it starts? Do you see the tach bounce around at all while it's trying to start? Might just need a battery refresh. You can maintain batteries by adding distilled water to each of the cells.
What does it mean if the tach is bouncing? Mine is doing that and won't start in the cold weather
zanzabar
I think it's that the signal from the crank position sensor is bad. Could be a bad sensor, problems with the teeth on the flywheel (i.e. there's a couple worn ones or it's just dirty) that the sensor reads, or maybe something in the wiring. Hard to say for sure and I'm not an expert.
I was having that situation on my 2007 2.5T (tach bounce and slow start) and thought I had fixed it by replacing the crank position sensor and doing battery maintenance. Unfortunately the symptoms are back and I'm not sure what's going on.
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
- 10894 Views
Last post by June
- 1115 Views
Last post by neworleans
- 1267 Views
Last post by ebolanore
- 803 Views
Last post by csh
- 670 Views
Last post by sane
