Oil on spark plugs H
Frosty33
- Year and Model: S60T5 2001
Hi I have volvo S60T5 the spark plug wells are filling with oil mechanic informed me spark plug oil rings are gone went to do job but have no idea were the oil rings go any help would be appreciated
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
I'm guessing you'll need to pull off the valve cover and replace the o-rings as well as sealant. Most cars I've worked on this is easy, just buy a new gasket. But in searching online it appears you need silicone sealant:
https://www.eeuroparts.com/Parts/46581/ ... l-0461680/
and the o-rings:
https://www.eeuroparts.com/Parts/47708/ ... g-0393830/
and the o-rings:
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
zanzabar
If the smoke abates, probably. If smoke continues no, that would mean it's getting into the cylinders from somewhere.
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
- Has thanked: 17 times
- Been thanked: 35 times
Just make sure the smoke isn't white and smells like donuts...check your coolant level. If it has reduced, you could have a warped head and burning coolant. This would call for taking the head off, making it true and installing a new head gasket. And by the way, you DO NOT use a silicone sealant on the valve cover. It needs to be an anaerobic sealant. You can buy non-volvo sealant of this type for less (check fcpeuro.com for it). Good luck!!
Frosty33
Hi had spark plug oil seals done on my volvo S60T5 by mechanic now car is running rough no 2 injector not firing then mechanic changes it with number 3 it works fine any idea please mechanic had car for 3 months now trying to work this problem out
- 3294 Views
Last post by ndphotonl
- 1382 Views
Last post by Ellipsis
- 30 Replies
- 6657 Views
Last post by PeteB
- 2290 Views
Last post by Wright Sounds
- 12 Replies
- 4581 Views
Last post by June
