Hello!
I have a 1997 850 T-5 wagon. Runs great,but a couple of days ago when I started it up the REC and A/C lights began to blink.
It blinks about 17 to 18 times,then it stops. I have read about this problem and some of what can cause it.
I drove it yesterday to narrow things down. I drove it for about 15 miles in stop and go traffic,outside weather temperature was 62 degrees . My blower fans runs great,it doesn't overheat the temp needle stayed in the middle. Heat work fine,so does the air conditioning. No smells either.
I'm a Volvo newb,so I need all the suggestions that I can get,LOL!!!
Thanks again.
Electronic Climate Control problem
- Been thanked: 4064 times
That blinking just tells you there are codes stored in the ECC control unit fault memory. You need a decent 'upscale' reader or Volvo software VIDA DICE for the 1997 model to read these out, then you will know its pain.
It could be something not worth worrying about, like a motor is slightly out of synch or the like, If your AC is working fine, its probably a damper or blend door error of some kind,
- AKJeeper
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 7 times
I just posted not too long ago on how to retrieve codes from the ECC system with a DIY tool. There's also other threads on the topic. Once you retrieve the codes, we should be able to help you out.
viewtopic.php?f=1&t=79406
- Has thanked: 2197 times
- Been thanked: 1850 times
Vida Dice does not work for 98 and older. Need to look for the correct OBD2 cable (I believe it is a VAG-com cable) and vol-fcr software. AJKeeper has a great how-to without the need for anything fancy.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I posted a short write up a while back on how to read the ECC codes...
viewtopic.php?t=50525
viewtopic.php?f=1&t=50443#p251189
Building a reader and getting it to work it pretty fun, and once you get the codes then we can help figure out what needs fixing.
- 11 Replies
- 6755 Views
Last post by maxi948
- 3476 Views
Last post by caliwagon
- 696 Views
Last post by Top Notch
- 1442 Views
Last post by jreed
- 1705 Views
Last post by mydamnvolvo
