Recently replaced a driver's side axle, five Bosch coil packs, new Volvo spark plugs, change to Mobil 1 0W40 in an attempt to cure lifter noise, new upper radiator hose, coolant, thermostat and ECT.
Went on 200 mile highway drive and popped the following codes:
P0328 -- knock sensor 1, high input
P0350 -- coil primary/secondary
P0442 --small evaporated. leak
P1081-- immobilizer
Car seems to be running OK,can't tell if there is an intermittent miss or not.
Any thoughts?
'99V70 Base, Auto, FWD -- Codes after recent work
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2200 times
For the immobiliser, if you had the battery disconnected during the work, try the old lock/un-lock using the key in the drivers door lock and re-set the code.
Evap leak could just be that. Depending on the year there may be an evap valve up near the radiator. It could have a loose pipe or connection disturbed during repair work.
As to the other 2. No clue what would through those unless a connector is poor, or one of the coils has a poor earth.
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
check your grounds.
