Stutter at idle
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
fartoright
Year and Model: 1989 245
Stutter at idle
Post by fartoright »
1989 245 dl. When I'm stopped at light with foot on brake the engine will stutter for a half second. The first time it did I thought someone hit my car. Started a month ago and would not happen often but now it happens about every 10 to 15 seconds while stopped. Does not happen while driving or accelerating only when stopped. Thank you for any advise.
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
This happens on my 960. Fuel system cleaner helps, but it is probably a firing issue. Check spark plugs and try running fuel system cleaner and some good higher quality gasoline through it.
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Brake booster?
1988 Volvo 760 Turbo Wagon
fartoright
I have a short day at work tomorrow. I'm going to change spark plugs cuz I just replaced mass airflow sensor. Car was running ruff and fuel was rich. You mentioned brake booster? I assume you are referring to a vacuum leak. I will double check tomorrow. I checked before saw nothing abvious but I'm going to take a closer look. Where is the leak most likely to be?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
fartoright wrote:1989 245 dl. When I'm stopped at light with foot on brake the engine will stutter for a half second.
Brake booster's diaphragm and/or its check-valve may be the issue.
fartoright
I changed the fuel pressure regulator. Spark plugs. And a used Bosch MAS. The car had a made in China MAS on it from previous owner. I increased the idle. It was idling way to low. She runs great now. I'm not sure what fixed it. The brake booster hose was fine. I took it off and inspected it. Thanks for all the advise.
93Regina
Post by 93Regina »
fartoright wrote:I increased the idle.
LH 2.4 idle adjustment FYI
fartoright
Thanks for that info. I have a friend who has had 240 and 740 s for 35 years. He ran me thru how to do it correctly. His phone calls sounded a lot like your article.
